tmk
Guest
Posts: n/a
Oil pressure gage.
When I turn on the switch the oil pressure gage will go to 5 bar and stay there after I start it. Is this a bad sending unit or a open wire from the sending unit to the gage or ?
TMK
73 914S 2.1L (the toy)
78 911SC (the driver)
Old 11-30-2000, 02:40 PM
lagoon
Guest
Posts: n/a
it should go down after it is warmed up. Afterwarm up, if you are doing 3000 rpm, your gauge should read about the same, if not a little bit more.
Old 11-30-2000, 05:35 PM
tmk
Guest
Posts: n/a
It always stays at 5 warmed up or cold.
TMK
Old 11-30-2000, 05:44 PM
pbs911
Guest
Posts: n/a
[QUOTE]Originally posted by tmk:
[B]It always stays at 5 warmed up or cold.
Which car does this happen to the 73 914S 2.1L or the 78 911SC? I know my 78 SC drops down to about 1 bar when idling warm.
Old 11-30-2000, 05:47 PM
BRAINIAC
Guest
Posts: n/a
Sounds to me like either the sender wire isn't connected or there is an open circuit in the sender. Since the gauge goes full scale with the key on, it's o.k.
Old 11-30-2000, 05:52 PM
tmk
Guest
Posts: n/a
Thanks to all. It is the 78 SC. I will try to get a sending unit and see if thats it.
TMK
Old 12-01-2000, 09:14 AM
BRAINIAC
Guest
Posts: n/a
One quick check before you buy a sender. With the key on (and the gauge pegged at 5 bar) go back in the engine compartment and touch the sender wire to a good ground. The gauge should now read zero. If it does, replace the sender. If it stays at 5 then find the open circuit between the gauge and sender.
Tyson Schmidt
72 911 cabriolet (964 bodywork)
Old 12-01-2000, 08:35 PM
