Trouble installing new control arm
After reading everything I could about replacing my control arm (a-arm) and ball joint, I'm running into an issue that another Pelican had mentioned, but now I can't find the post.
Basically, I have the balljoint installed, and the rear end of the control arm installed and bolted thru the crossmemember, but the new control arm is "longer" than the one I removed. Not the arm itself, but rather the position of the front mount is not aligning with the mounting holes in the tub. Hopefully the guy(s) who ran into this and posted it will read this post, but does anyone have any suggestions on how I should get it to align? The angle of the front mount is also rotated about 20 degrees clockwise (from the front) compared to the control arm I am removing. I assume I can just put a jack under the rear of the control arm to rotate it into position (pre-load the bushing), but I don't see how I can do that AND shorten it. This is a NOS control arm with factory bushings. |
Found it!
Of course, after posting, here it is (on page 2 of the nearly infamous Island vs. Chuck rubber bushing thread)
http://forums.pelicanparts.com/porsche-911-technical-forum/266716-rubber-arm-bushing-question.html Quote:
Thrasher, I hope you have success in getting them to fit. Like I said I had a friend of mine under the car at the cross member with 2 large c-clamps compressing the bushing at the cross member. I was at the front mount pushing the a-arm inward toward the crossmember and trying to start one of the front mount bolts. Quite a project. When measuring the new and old a-rmes you will notice that the bushings on the new a-arms are actually expanding the length of the a-arms. If you have any questions feel free to ask, Jerry
Thanks Jerry. Is your friend available on Saturday?
Just kidding - I suppose I'll just have to keep going from one spot to the other to see when things align. Luckily I'm only doing one side, as the PO had the passenger side done recently as part of a repair. The asymmetry of it all was too much for me to bear any longer! |
Very interesting. My new Porsche a-arms just slid right in. No problems at all.
Rob, Thrasher- as far as I know there is only one manufacturer for these a- arms, no aftermarket. I would think they are all pretty standard? Wonder if anyone else had this problem or if they slid right in? Jerry
| All times are GMT -8. The time now is 12:57 AM. |
