TMo TMo is offline
Coupe conversion?
Is there a good reason NOT to convert a cab into a coupe? The car started as a targa and was cut into a cab in the 90's. And had a wide body conversion at the same time.
Besides finding a decent roof clip and having it welded together, along with adding all of the stock parts, what else would I need?
Old 04-03-2023, 01:40 PM
MConn's Avatar
I put a 1969 roof on a 1987 targa. This was the only time I have ever done anything like this. Here's some issues I had to work through:
I made metal jigs for the front windshield, back windshield, and rear quarter glass to make sure the glass openings were close enough.
The A pillars were different widths, and I didn't fix them - so you can see the change in thickness from the inside of the car. I added a metal spline into the pillars to add some strength.
Try to get the headliner rods with the roof, because they seem to vary.
I had a heck of a time getting the roof to the back of the C pillars correct.
The interior trim for coupes is different from the targa so I had to custom make the rear quarter window interior trim.
I don't regret it, and it turned out better than I expected, but it was a lot more work than I expected.
Mike
The more I learn, the less I know.
Old 04-03-2023, 03:55 PM
Grappler
Rodsrsr's Avatar
What year is it? Might make a difference.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 04-03-2023, 04:02 PM
TMo TMo is offline
It's a 1980. It's supposed to be delivered next week so I can't take any measurements yet.
Old 04-03-2023, 06:09 PM
Grappler
Rodsrsr's Avatar
For a 1980 I don't see an issue with converting to a coupe. Cool project.
Grappler
Know Gi / No Gi
Old 04-03-2023, 06:20 PM
Here’s a 1980 targa I converted using a mid year roof. Had many of the same issues/ concerns as Macon. I used titanium rods inside the A pillars with 3m structural adhesive along with welding. A roll bar at the least I would recommend. I hung an electric winch from the ceiling and used ratchet straps to lower and raise roof about 300 times. Glad I did it came out better than expected, a few what the hell did I get myself into moments but eventually it all worked out. I wouldn’t do it to a nice blue chip car.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 04-04-2023, 06:20 AM
Before and After shots of my 1969 E (non-numbers matching to start with). I took the same route as others putting rods in the A-Pillars for extra strength. We did the conversion without really touching the rear of the car where the Targa glass once sat.
Bill
Old 04-04-2023, 06:48 AM
Nice Bill, I too left as much alone as possible.
Old 04-04-2023, 08:18 AM
