pedal assembly removal
I'me trying to remove the pedal assembly on our 74.
How does the clutch cable unhook?
How does the assembly remove?
I have the master cyl off, all the mounting bolts on both side of the tunnel off, disconected the accelerator cable.
Do i have to remove the roll pin from the clutch pedal?
Does anyone have a scematic? Thanks, Col.
Boilermaker......another young man in an old man's body.
Col.
3-'74 911 targa.
Old 02-09-2007, 11:49 PM
Ahhhh, remove the roll pin! Marvellous what 2hrs of searching will find,
I still dont know how to remove the clutch cable though!
Col.
3-'74 911 targa.
Old 02-10-2007, 12:55 AM
slodave's Avatar
Which end of the cable? If at the pedals, once the wooden angled floor board is removed, you should be able to see behind the gas pedal, but in the center channel. There is a clevis in there that attaches to the clutch pedal. Hope this makes a little sense.
Dave
EDIT: Hmm, yeah, it's late. Your car is ten years earlier and the assembly is different. Sorry.
Old 02-10-2007, 01:06 AM
