cis fuel injection connectors
The is a 2 wire plug directly behine the air control box, I cannot find a place to plug it in. It is located seceral inches to the right of the accelerator linkage, where should this plug go?
Old 02-11-2007, 06:21 PM
The cold start injector is back there - it's a PITA to reach. You'll need a mirror to see it.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 02-11-2007, 06:29 PM
So is the air flow switch connector and it is identical to the CSV connector other than color coding. See:
CIS works only then starter is on
Old 02-11-2007, 06:41 PM
