Need help identifying electrical wires
Can someone please help me identify the wires on the pictures?
Pic 1 - (bad quality...) taken under the rear left tire, looks like the wire is a "gold" color. http://forums.pelicanparts.com/uploads9/11171140575.jpg Pic 2 - The wire comes ouy near the freshair blower in the trunk (right side). Behind the speedometer/tacometer.... Wire color Yellow. http://forums.pelicanparts.com/uploads9/21171140912.jpg Pic 3 - Same destination as "pic 2". The wire comes ouy near the freshair blower in the trunk (right side). Behind the speedometer/tacometer.... Wire color brown with withe stipes http://forums.pelicanparts.com/uploads9/31171141004.jpg Pic 4 - Picture taken off the rear windows. The yellow ones are from the window defroster (i think...). but where to connect? Don't know the brown and the red ones... Where to I connect this? http://forums.pelicanparts.com/uploads9/41171141133.jpg Pic 5 - Where to connect this blue wire? http://forums.pelicanparts.com/uploads9/51171141201.jpg Thanks! /Joachim |
best bet is get a haynes or factory manual with a wiring diagram, porsche is pretty good about color codes. brown is always ground. Don.
What about brown with white stripes? Also ground?
/Joachim |
FYI: The wire in pic 1 is bronse!
/Joachim |
solid brown is ground, ppsite has a wiring diagram but a little hard to make out details. haynes has black and white pic, perfectly workable, fact manual has beautiful color plate. I scanned my plates but file to big to post here. send me your email and I'll try to get them to you that way. Don
You don't say what year your car is. Schematics for several years can be found here. Pick one that's close to your car's year. |
It's a 1974 911S 2.7 (US)
/JOachim |
