Tips on Carpet Fitting Needed
I finally got round to removing the sill sections (had to remove the seat support brackets as the carpet was fitted under them) and front map pockets - the last of the carpet removed that I intend to replace - i.e. from the B post forward.
Southbound have provided me with the carpet sections (black, and not perlon) and 500ml of glue. Before I start, please give me your tips :- - should I fully remove all traces of old glue, and if so, how ? http://i124.photobucket.com/albums/p...g/DSCN1331.jpg - should I strip and coat the floor and inner panels with POR ? - should I glue around the carpet edges, or all over ? - should I apply glue to the carpet and bodywork ? - especially need advice or pictures on how to make the map pockets, as the carpet and pocket is just one big long section - should I remove the old rear parcel shelf foam ? http://i124.photobucket.com/albums/p...g/DSCN1340.jpg - does anything cover this hole at the front centre ? http://i124.photobucket.com/albums/p...g/DSCN1265.jpg As always, thanks for your help, and hopefully this might help others in time. I have posted base interior pictures on my photobucket. Let me know if this all looks sound to you. Ian |
| All times are GMT -8. The time now is 07:24 PM. |
