-   -   930 transmission, no reverse (http://forums.pelicanparts.com/porsche-911-technical-forum/330014-930-transmission-no-reverse.html)
wmoon68 02-12-2007 10:34 AM
I have a '77 930 and can not engage reverse with the engine on or off, everything else works fine, what could be wrong and where should I start?.
Jim Sims 02-12-2007 07:07 PM
Shift coupler adjustment or shift coupler bushings are bad. Look under cover plate on tunnel behind front seats.
john walker's workshop 02-12-2007 08:21 PM
i've repaired at least one reverse shift fork that was bent enough to keep reverse from engaging. under the trans end cover.
