1986 911 fuel problem maybe
Hi
anybody experience this [problem} Sometime my car stop running when I'm driving..If you sit a few minutes it will start up again and drove away no problem....sometime twice a day or every month....sound like I'm out of gas....???Thanks
Old 02-04-2007, 10:35 AM
How long has it been since the fuel filter was changed?
Old 02-04-2007, 10:38 AM
Goth's Avatar
DME Relay?
Doug
84 Carrera Coupe - Black (the Goth look)
The more I learn, the more I realize I don't know
Old 02-04-2007, 01:04 PM
BT911's Avatar
i'm having the same problem right now and i've replaced the DME relay and fuel pump. i'm thinking it's a bad DME
Old 02-04-2007, 01:06 PM
Old Member
DME relay.
Cheap to replace and you should always carry a spare in the car.
Clifton Brown
https://www.mancalamarketing.com
Old 02-04-2007, 01:46 PM
WydRyd's Avatar
Could be intermittently failing DME relay.
BTW, there are two types, a 15A unit and a 30A unit. These are the same right? Just higher amperage capacity in the newer 30A units?
I was fooling around with my Motronics box on the weekend and decided to swap out the old looking DME relay. It worked fine, but since I was in/under there, I decided to fit the 30A unit in it's place.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 02-04-2007, 05:01 PM
I change it twice in ten years......But I stop driving the car for six years.
Old 02-06-2007, 04:22 PM
Thanks for the input...I will replace the DME relay...
Does this DME relay effect the Idling??
I can hear the motor RPM goes up and down..... I know my fast idle isn't working right ,,sometime the motor back fire in the morning....... As long I let warm up first brfore drive away ...
Old 02-06-2007, 04:31 PM
"But I stop driving the car for six years."
This could mean a rusted fuel tank and rust in the fuel clogging the fuel filter. How long ago was the fuel filter last changed? Six years ago? Six months ago?
Old 02-06-2007, 06:31 PM
six year ago...
Some how the car will start right up after sitting 2 or 3 minutes later..
But if I tried to start right after stall is won't start. To me is sound like the warm up start problem.. But I can be too sure...
Old 02-12-2007, 10:25 AM
