-   -   Need more power!! is it possible ? ( 911 -79) (http://forums.pelicanparts.com/porsche-911-technical-forum/33002-need-more-power-possible-911-79-a.html)
bjarte 12-05-2000 03:07 PM
Is it possible to get more horsepower on my Porsche 911 SC 1979 ? It is normally 200 HK in this car.
If possible, how much must we pay for this ?
Porsche lover
orbmedia 12-05-2000 03:26 PM
How much power do you want? Do you want power across the RPM range or can you live with peaky power near the top of the throttle band? What is your budget?
bjarte 12-05-2000 03:35 PM
Just bought the porsche,and know this car make 0- 100 km/hour on 7 sec.
Just wanted faster like 6 sec.
I have not thought about the budget, just love the car and love to accelerate.
thanks for answering
bjarte
Porsche lover
mikez 12-05-2000 03:45 PM
Cheaply, you can backdate the exhaust by using 74 style stainless steel style heat exchangers and dual outlet muffler. If you have smog inspection in the area you live, you will not be able to pass a visual inspection though.
Another upgrade would be to use 964 cams. These will work well with the CIS fuel injection.....further upgrades would be to Weber carbs.....
bjarte 12-05-2000 03:51 PM
Do you know how much it will cost ? (both examples)
Gary Peters 12-05-2000 04:46 PM
Being that the car was originally from Germany it probably already has a good exhaust system. With the good exhaust there aren't any cheap ways of getting more power from this engine. The next step would probably be putting on Weber or PMO carbs and a good set of cams. Bruce Andersons book The Porsche 911 Handbook is a must read to find out what to do on it. Unfortunately it is more focused on the US spec engines.
'76 911S
'80 924 M471
bjarte 12-05-2000 04:52 PM
Do you have any idea what the cost for this will be in dollars ?
mikez 12-05-2000 05:11 PM
Exhaust, oil lines, gaskets and muffler, $1200 USD
964 cams, removal of engine and fuel injection labor and cost of cams. Cams will run $400 USD
Weber Carbs with manifolds and air cleaners, used about $1200 USD, new (PMO only, Weber clones) $3,000 USD.
bjarte 12-05-2000 05:18 PM
oops!!
That will be a lotof money in Norway. I belive, probably around the double, ****.
I need to work more guys
Thanks anyway
mikez 12-05-2000 05:25 PM
Welcome to the money pit....8^)
