Highfield's Avatar
Home Covered RS Door Panels - Part 1
If you have been following my internal refurb posts, you will know that I have flat plastic door panels, as fitted by Tuthills to their rally cars.
I wanted to cover these to look more like an RS panel, so ordered foam and vinyl from Southbound.
The original panels being plastic did present a problem in that you cannot staple in to them, so I decided to use gaffer tape and even a tiny bit of super glue !
Here is how I went about it :-
1. Lay the plastic panel over the foam and mark with a pen, then cut out.
2. I used some spray mount glue to loosely stick the foam to the plastic, and a few pieces of gaffer tape to hold the foam steady whilst I flipped it over on top of the vinyl. I then cut the vinyl slightly larger than the panel to allow it to be wrapped over and taped.
3. I then cut the hole for the window winder and pulled the vinyl through and glued. I then pushed a skewer through the original handle and mounting screw holes from behind to make a small hole in the vinyl.
Part 2 can be read here :-
Home Covered RS Door Panels - Part 2
Ian
Ian Highfield
1992 964 C2 Manual with RS Suspension etc.
1973 911T Narrow body Hot Rod with 2.7 Carrera engine and loads of period modsl - SOLD
1986 Carrera Coupe Sport with Stainless Silencer and SW Chip (256 fwbhp) - SOLD
Old 02-12-2007, 10:33 AM
