High Temp Clear Coat on muffler
I am having my stainless steel muffler bead blasted. Instead of painting it, I thought it might look good with a High Temp clear coat. I see one - VHT - that is good to 1500 degrees F.
Has anyone tried this? Do you think it will hold up? Any opinions on the look?
Brad Inventor of SNAPGAP - The Valve Adjustment Solution Patented in U.S. and Europe. Go to SNAPGAP.US or PM me. https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146 |
why? it's stainless steel, just leave it as is.
-matt
BMW 128i 73 rsr clone - sold 68 912 project to become 911r (almost done!) |
I figured it would rust again, won't it?
if its stainless steel it is not supposed to rust.
- Tyler 1988 911 Carrera Grand Prix White/Black 2015 Cayenne Diesel Black/ Luxor Beige/Black |
Depends on what type of "stainless" it is. Coating it might be a good idea.
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Get it JetHot coated, that will protect it and not come off.
-Britain
'69 912 w/ 2.3L Type-4 Turbo Engine '74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans. '80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks -- www.britainracing.com -- |
