too many projects 1983 sc
56 nomad's Avatar
need help install cable release on a long hood
hello,
did a search couldn't find the answer...wil some one direct me to a site that will tell me how to install the cable . it wll fit/pass through but will not push in all the way (the collar with the lock binds). do you have to use some or a lot of gentle persuasion to get it to seat and after that how do you lock it into place...there also looks like some place for a pin to be used to secure the cable to the body. any advice is very much appreciated.
ben
Old 05-18-2012, 11:13 AM
56 nomad's Avatar
still trying
a little help please, i cant be the only one that has had to install a new cable...do i use brute force and "pound " the handle with the lock into the shaft or were there different sizes and by chance mine is the wrong one...just will not fit. i am trying to find out if there is a trick to this install or if the replacement cable is the wrong one before i go to the trouble to send it back. thanks for the help ,ben
Old 05-19-2012, 04:28 PM
HarryD's Avatar
What year is your car? If you do not mind, add your year and model to your signature line.
While I can offer no help, at least someone with a similar year may be able to help you.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 06-23-2012, 06:26 PM
HarryD's Avatar
Duh, Saw your model in you post.
Is your car a Coupe or a Targa? I saw the cable in Automotion but looks like a coupe one.
Looking at the PET, there are two part numbers 911-511-037-00 and 911-511-037-01 (Model M637).
The PET lists two different cables (one for targa and one for coupe) for my year.
I wonder if you have the wrong one?
Harry
2020 MB E350 4Matic
Old 06-23-2012, 06:41 PM
