effvee's Avatar
911 Fan and ring ID
Can anyone ID this 911 fan and ring for me. 901 106 101 5R. It's going on my Super Beetle German Look using a type IV engine.
260mm fan and ring, marcell alt 75amp
I can be contacted at fvercher@charter.net
Old 02-15-2007, 02:11 PM
304065's Avatar
Measure it again, it's not 260mm, it's 245mm. Casting pattern from later cars, coil studs should be at the 10:00 position. 901 casting number ending in 5R means it's pre-78. 75A Motorola/Marchal alternator gives it away, bigger than the earlier 55A from the 2,2-2,4, so what you have is a fan housing from a 2,7 911 1974-1977 and a fan from a 1969-1975 911.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 02-15-2007, 03:07 PM
effvee's Avatar
thank
John thank you.
At present There are only two good 911 shroud makers for the type IV engine going into a bug.
The red shroud is made by Mr. Rolf Klaus.
The blue shroud is made by Mr. Eddie Remmele
I prefer the Mr. Klaus, however Mr. Klaus shroud is made for a 225mm custom assembly. I just don't want to start all over again by buying Mr. Klaus system.
Mr. Remmele, has a well deserved bad rep of getting one funds and falling into a black hole. Both gentlemen live in Germany. Since you have enlightened me to what I have to work with, I may take the path of doing one myself. In the how to modify your 911 I see there are I believe four shroud for the 911. I have noted a green one I like. If I were lucky enough to get a shroud, and maybe the deflector that attaches to the rear of the interior alt area, would this cooling system keep my car cool running?
Old 02-15-2007, 06:09 PM
