jtkkz's Avatar
Question drilling fiberglass fan shroud
I bought a new amber fan shroud....
what is the best way / tools used to drill holes in it...
Multi-flute reamer?
Helix drill bit?
Old 02-16-2007, 03:38 PM
gestalt1's Avatar
a regular drill bit will tear it up and crack the fg too much. i used a zip saw - used for cutting drywall for outlets etc.. worked great.
-matt
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 02-16-2007, 03:43 PM
jmshepard's Avatar
I used a Unibit step drill. They work great on all plastics.
I say we take off, and nuke the site from orbit. It's the only way to be sure.
2009 Cayman
Old 02-16-2007, 03:44 PM
jtkkz's Avatar
Do you still need to drill a small pilot hole first, then use the unibit step bit to drill the bigger holes..?
Old 02-16-2007, 03:50 PM
jtkkz's Avatar
Will this work fine with my fan shroud?
IRWIN 10233 UNIBIT 3, 9 Hole Sizes 1/4-Inch-3/4-Inch in 1/16-Inch Increments
Ideal for drilling holes into thin materials such as stainless steel, copper, brass, aluminum, plastic and laminates
Old 02-16-2007, 04:00 PM
Early_S_Man's Avatar
Porsche Crest
Dremel Tool & carbide PC board router bit ... a tiny version of a Roto-Zip bit.
http://www.goldmine-elec-products.com/prodinfo.asp?number=G15898
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-16-2007, 04:12 PM
jmshepard's Avatar
I used a similar Unibit the other night on my shroud.
It was the bit with the smaller series of holes.
I did not drill a pilot hole.
Jim S.
2009 Cayman
Old 02-16-2007, 04:14 PM
jtkkz's Avatar
How do we drill the bigger holes 3/4"
Early Porsche Reproduction Products:
http://sycipworks.tripod.com/
Old 02-16-2007, 04:17 PM
jmshepard's Avatar
I would buy two Unibits. Use the smaller to start a pilot, finish with the larger to 3/4".
Jim S.
2009 Cayman
Old 02-16-2007, 04:20 PM
Johnb911's Avatar
If in doubt drill plastics and fiberglass at highspeed backward.
Especially the first and last bit.
Its slow but it won't chip or tear on the way in or out the otherside.
It's also a good idea to drill untill the tip gets through and then flip it over and drill from the other side.
That way you are in the middle of the glass when you grab the last bit with the drill. Less chance of tearing.
JOHN
79 EURO SC
"24 Years Later - The Dream Came True"
Old 02-16-2007, 04:43 PM
Information Junky
island911's Avatar
Well heres a re post of mine...
Originally posted by island911
here you go, 5-x . . .
the diamond shape toothed Tungsten Carbide Cutter;
and, far from your average drill bit;
'nuff detail of the cutter geometry?
I suposse, next your going to ask for speed & feed rates.
(2800rpm @ 1.5thou/rev)
But really, for the bigger holes, think about composites being most like wood ... lots of wood-bits out there. (typical Forstner or spade bits)
For the small stuff Warren has it right, Carbide Dremel bits.
Old 02-16-2007, 04:53 PM
Cheap chinese "forstner" bits work great for larger (3/8" up) holes.
regards,
Phil
Old 02-16-2007, 04:57 PM
haycait911's Avatar
for small holes 'blair' bits work well, basically a small hole saw. for larger holes, 1/2 inch up, well, a hole saw. but a sharp one! It's also a good idea to drill untill the tip gets through and then flip it over and drill from the other side.- very good advice. Don.
Old 02-16-2007, 05:43 PM
Remember
The Turk's Avatar
I just used this the other night to make a ¾” hole, it worked great, I got it at Home Depot.
Good Luck.
Gary
1975 911S G50 3.5 Twin Turbo
Old 02-17-2007, 10:50 AM
