1989 carrera speaker problem, please help!
HI i have just changed the front door speakers and they worked fine. I then changed the rear speakers which work fine, but now the front ones dont! I havent changed any wiring just the crimped on parts which connect the cable and speaker.. can anyone help?
Is there a fuse for this or is this something more major? Any help would be great guys. Terry |
undo the wires at the deck. I'm assuming they are crimped or tapes. They key is that you do it at the deck. Then take a 9 volt battery and attach it to the pos and neg wire going to the speaker. You should hear and see somthing from the speaker. You can also do this with a signal/tone generator. What this tells you is that your wireing is good and it's a deck issue. Also, note if two speakers are making a noise when only one should be. That will tell you somthing is iffy about the wiring. It sounds like a deck issue or you have a short in your wiring somewhere. hope this helps.
Make sure it's not something simple like the fader control on the head unit.
Good point.
Thanks guys i will check in the morning!
| All times are GMT -8. The time now is 03:36 PM. |
