Unhappy More surprises
Discovered more issues on my '76 911.
1. 3mm end play to the distributor shaft.
2. Chain noise on left side in chain box.
3. Leaking at head gasket interface (head-to-barrel).
4. The worst...the studs might be failing.
Advise would appreciated. Can't afford the rebuild right now. I was quoted $9000+. How much to fix problems 1,2, and 3?
Old 02-17-2007, 05:27 AM
goldsc78258's Avatar
Send a message via Yahoo to goldsc78258
Don't think about 1,2 and 3 till you can fix 4 , you can live with the others, but if the studs fail the engine is toast
Old 02-17-2007, 05:53 AM
DRV2FST's Avatar
I am not a mechanic so I can't help with the estimate, but every time I have tried to go cheap on repairs for a 911 it has cost me double what it would have if I had done it right the first time.
Kirk
Crashed: Silver 1992 Turbo S2
Sold: '86 930 minor mods; '94 3.6 Turbo; '85 Euro 930 (3.2 Intake, Tec3r EFI, TwinPlug, Garrett Turbo, JE 8.1 Pistons, 505 rwhp)
Old 02-17-2007, 05:54 AM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
I agree with goldsc78258, you have to get the head studs fixed right away. There are several very good tech articles on how to remove the old ones and replace with new proper studs.
After that I'd move onto the chain tensioner (that's what I think you meant). Great articles on this one too. Follow their advice and you'll get through it pretty well.
I wouldn't worry about the head to barrel gasket unless there is a continual stream coming out of it.
I have no idea about the distributor shaft, but I'm sure others do.
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 02-17-2007, 06:04 AM
Early_S_Man's Avatar
Porsche Crest
I don't think you can do those piecemeal ... without expecting a bit of irony and disaster over the horizon.
If you let #1 go for now ... the distributor drive gear could exit the case to the left sideways and take out the case with it! The solution is fairly easy: new fiber washers, spring washers, and shims form a motor/alternator rebuild shop. This thread explains the disassembly, cleaning and refresh procedure:
distributor lube...
The #2 problem is easily assessed after you take off the muffler.
The #3 problem will be easily rectified when you take care of #4.
If you aren't or haven't been a DIY person ... you may want to start looking for an engine transplant.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-17-2007, 07:28 AM
