-   -   Targa wind noise solution (http://forums.pelicanparts.com/porsche-911-technical-forum/33090-targa-wind-noise-solution.html)
wmtt140 11-30-2000 06:13 AM
I had been experiencing a lot of wind noise on the '90 Targa I recently purchased. After searching for a number of solutions which only helped a little I came up my own.
I purchased an automotive sponge and a roll of double sided tape. I cut the sponge in roughly 1" X 1" rectangular strips and attached it under the front lip of the roof behind where the roof seal would contact the roof. You don't want to install were it would contact the rubber seal as this would raise the lip of the roof and catch the wind. I also applied the sponge along the front of the targa frame. Wind noise is almost non-existent now.
Wayne
1990 C-4 Targa
TonyC 12-05-2000 08:10 PM
Wayne I've got the same problem. It sounds like you put the pieces on the targa top so it doesn't show up when the top is off right?
Tony
87 Targa
wmtt140 12-07-2000 05:43 AM
You are correct. The only time you can see the foam is on the Targa top when the roof is off.
Wayne
1990 C-4 Targa
TonyC 12-09-2000 06:44 AM
Thanks Wayne, I am going to try that tomorrow!
Tony
87 Targa
