Please help identify
Hi Guys,
My engine is out for a clutch job, and the mechanic noticed that there were a few things not right. In the first picture, the valve pictured was taped off. Can somebody tell me what it is? Also, in the second picture, this hose was off. I assume it's a vacuum hose of some sort. Anybody know where it goes? Thanks a lot, Adam http://forums.pelicanparts.com/uploa...1171733390.jpg http://forums.pelicanparts.com/uploa...1171733413.jpg |
Has your cruise control been removed? In the first picture the small vacuum hose goes to the cruise control canister which can be located back behind your fuel filter on the back, driver's side of the engine compartment. In the second picture the big hose is a vent hose that goes from the cruise control cannister down into an open area in the frame area between the shocks.
thanks for your reply Kurt.
Since i've had the car it never had cruise control, so thats interesting to learn. Perhaps it was removed by a PO |
| All times are GMT -8. The time now is 07:55 PM. |
