ChrisL
Guest
Posts: n/a
Broken cable on a closed sunroof
Anyone have a method of removing a broken cable if the sunroof is closed? The first step is to slide back the cover under the sunroof itself - there doesn't seem to be a way to get to the front clips unless you open the sunroof a few inches.
Also, should cables be replaced as a pair, or should I only replace the broken one?
Old 12-09-2000, 11:52 AM
freefly
Guest
Posts: n/a
I am not sure on this (I own a Targa), but I believe your car has a manual crank for the sunroof, just for such an occasion. It seems that the access point is under the headliner, behind the sunroof, but I could be way off base.
-EJ
Old 12-09-2000, 12:09 PM
ChrisL
Guest
Posts: n/a
The crank is useful if the motor is not functional.
I tried the hand crank and one side begins to open but the other side won't budge. I didn't want to force it for fear of breaking something.
Old 12-09-2000, 02:24 PM
dean
Guest
Posts: n/a
I just did my cables. You can pry the headliner down with the sunroof closed. Then slide the headliner back.
Dean
Old 12-09-2000, 06:02 PM
