Fan is hittin on 77 911
The fan is rubbing the housing when it is spinning and has been for a while. The contact is not heavy but noticably if you really listen for it. What typically causes this? The alternator is relatively new, maybe 6-7K on it. The housing is the original.
I do not have any over heating issues. I am surprised after drving like this for a while that one of the two pieces would have wore down. Anyways, probably time to fix.
Any opinions?
Old 02-17-2007, 06:12 AM
Try loosening the alternator stap, to tight and the fan will rub.
Old 02-17-2007, 07:29 AM
Will program for food
ghnat's Avatar
If you can hear the rubbing I would suggest taking the whole assembly out of the car and inspect the housing for cracks. First thing I thought of was worn alternator until you mentioned how new it was. My housing had, oh about 4 cracks in it. There was no rubbing, but it would be only a matter of time. You could buy new Aluminum one or try to get the mag one welded. I have heard about some issues with the aluminum ones, but I think someone with more knowledge will chime in.
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 02-17-2007, 07:34 AM
I'm embarssed to say that I know the car will still run with the fan housing improperly installed. Look very closely at the bottom timing notch. I had to redo mine after the alternator installation, took some determination to set right.
Old 02-17-2007, 07:58 AM
I would be surprised if it's possible to weld magnesium.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 02-17-2007, 08:27 AM
Picture of bell lip over bottom pulley, not behind it.............do not do this!!!!!
The fan noise might be becuase of this, although you would be eating belts very quickly.
Alternator Ground Strap
Old 02-17-2007, 08:34 AM
I'll try and loosen the belt using an extra shim. Seems like a great place to start.
Thanks,
Old 02-17-2007, 07:01 PM
dweymer's Avatar
I had the same issue, and found my bolts that hold the air guide on , and hold the alt in the housing were loose on top. May want to double check them.
Donnie
Currently Porsche-less.....
Old 02-18-2007, 05:50 AM
+ lurking - contributing
If you find the alternator mounting bolts are loose, you are lucky.
My fan rubbing was caused by cracks in the magnesium housing, specifically at the alternator ring support braces. Magnesium degrades over time, especially in humid climates. It is a good idea to pull the whole assembly and inspect for cracks/warps. Depending on your model, there are OK quality OEM housings available from various used parts suppliers. Vertex makes an all aluminum one but may take some force to fit.
Let us know what you find.
96 BMW M3 Coupe
89 951
08 Astra H
Peugeot moped
Old 02-18-2007, 06:22 AM
Shaun @ Tru6's Avatar
consider yourself surprised. Mg can be TIG and arc welded.
hi David.
Tru6 Restoration & Design
Old 02-18-2007, 06:53 AM
what! come on we do this every semester for our students to show them it is indeed very possible and works very well.. I have fixed many of fan blades and a couple of housings. that said once the housings crack they typically have a bunch of cracks which don't make it worth while
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 02-18-2007, 09:33 AM
That's interesting. I remember watching an F2G Corsair crash with its magnesium firewall on fire simply from the heat of the burning gasoline. So yeah, consider me surprised.
Stephan Wilkinson
Old 02-18-2007, 09:41 AM
Here is a fairly readable update from the FAA that touches on the issue, if small bits (dust, bits, strips) get heated to melting point watch out. This was always a great demo in HS chemistry lab with VERY thin strips of Mg
Richard Lane
1978 911SC
1973 "Clean" RS clone
Old 02-18-2007, 10:55 AM
remember we are using an inert gas (argon) so there is no oxygen present to allow it to burn just melt.. the dust however now thats different
Ben
89 944,85.5 944
914-6werkshop.com
Old 02-18-2007, 10:58 AM
defcon65's Avatar
Can't be as impressive as dropping a tiny bit of sodium wire into a bucket of water...
Make sure the alt shaft washer behind the fan is on the correct way so the little flange sticks out, mine was rubbing on the housing because this was reversed...
Regards,
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 02-20-2007, 01:14 PM
