-   -   Need a part number for a bilstein strut seal (http://forums.pelicanparts.com/porsche-911-technical-forum/331102-need-part-number-bilstein-strut-seal.html)
edbaus 02-18-2007 04:41 PM
I can not seem to find the part number for the seal that goes on the bilstein strut tube.
This is the one that acts as a wiper seal for the strut tube as it goes up and down in the housing.
It actually mounts in the end of the strut tube and the strut slips inside of it.
Ed
tctnd 02-18-2007 05:30 PM
Smart Racing Products can get it for you. The original style with a rubber exterior that was simply pressed into the strut housing is NLA. The replacement has a metal outer surface and is not a press fit. I spoke with a tech at Bilstein of America who confirmed that this is the current correct seal and said they glue them in with silicone.
regards,
Phil
jstgermaine 02-18-2007 05:39 PM
Ed,
The part you are looking for is called the fettkape (sp?) pronounced (fetcap). It was available as late as 4 months ago when I purchased mine directly from Bilstein. I think it was around $15.00 shipped.
Maxhouse97 06-18-2017 06:50 PM
Reviving this old thread - anyone know the right part number? I found this website:
BILSTEIN SEAL KITS
Maxhouse97 06-22-2017 06:51 PM
Bump
Indescikov 06-22-2017 07:39 PM
Contact Elephant Racing.
They have the correct seal.
Good people to deal with.
P/N not listed on their web site.
Luccia at Pelican Parts 06-23-2017 10:35 AM
BILSTEIN SEAL KITS
If you don't get much advice here please give Glenn a shout at 1.888.280.7799 x240. He might be able to further assist you. Good luck!
Indescikov 06-23-2017 12:10 PM
Not to sound like a broken record.
The Bilstein shock struts had two inside diameters where the seal is installed.
The earlier struts used a seal that was basically all rubber with internal metal reinforcement and had a slightly larger inside diameter (believe to 46 mm)
The later struts used a seal with a metal outside reinforcement and an outside diameter of 45.5mm
The seals to fit the earler struts are NLA
The seals that fit the later struts are readily available, though the part number is not well documented.
The seals are a press fit in the later struts and a very loose fit in the earlier struts thus the comment about having to "glue them in". This is due the difference in the inside diameter at the top of the struts. (early=larger inside diameter/later=smaller insider diameter)
The guys at Elephant racing were a big help and have the currently available strut seals, with no disrespect to our host.
This dependent on the year, earlier struts used a seal that was basically all rubber
Later model on left and earlier on right. Note the metallic outside diameter on the later (current) model seal
http://forums.pelicanparts.com/uploa...1498244709.jpg
Strut seals installed
Maxhouse97 06-24-2017 07:54 PM
This is great thanks.
