911chips Chip install update..INSTALLED
Directions from 911 chips are right on. However I did remove the seat. My switchs where broken so I could not fit the 10mm socket to remove the big MO.
After cleaning the unit off I gently pulled back the tabs and seperated the two halfs. I used a small screw driver to pry the plastic tabs and VIOLA we have seperation. From there it was straight forward. I did some minor cleaning under the seat area. simply reinstall and your done
Fired right up.
WAY different sound....remember I have the muffler off at this time.
The sound now is much more crisp at idle I MEAN MUCH more crisp. I dont know if the chip increases idle ignition advance but it would appear to me that there is more cylinder pressure at idle...
I did not drive it I just started it quickly as to not wake the neighbors.
Old 02-20-2007, 08:28 AM
Slippery Slope Victim
NY65912's Avatar
Aleluia....another convert!
You're gonna love it.
MikeČ
1985 M491
Old 02-20-2007, 08:55 AM
