-   -   test port pinouts (http://forums.pelicanparts.com/porsche-911-technical-forum/331450-test-port-pinouts.html)
dfink 02-20-2007 02:17 PM
test port pinouts
Just curious about the pinouts on the test port for the 3.2 engines. I know that two of them are jumped when setting idle but what are the others for. Could find anything doing a search.
dfink 02-21-2007 06:21 AM
Nobody.....
dfink 02-22-2007 08:32 AM
Someone must know something.....
equality72521 02-22-2007 08:48 AM
You may find reluctance to give advice on this subject. Even if I knew the answer I would be hesitant to tell you for fear of helping you burn up something expensive.
dfink 02-22-2007 09:28 AM
Ah somebody is always telling someone to stick something someplace. I have had nearly every part of this car apart and poked stuff already where I probably shouldn't have. I am going to assume that the test port has some function other than centering the ICV for mixture setting which I have done and don't think anything burned up yet.
