Jascha's Avatar
Footwell blower motor replacementů (?)
Looking for a replacement source for the existing motor that is inside the footwell blower assembly (x 2). The original motor was made by AEG (part # W960 80075)
The complete unit (housing, fan, et al) has a Porsche number 911.624.043.02 (left side) and 911.624.044.02 (right side) but they tend to be pricey
Pictures are shown without the plastic shrouding / housing
Old 02-20-2007, 06:26 PM
ianc's Avatar
Hey Jascha,
Thanks for making the new post. Yes, I have had these guys out. Only one of them is squeaking and I have disassembled it and oiled the felt pad. Brushes and bearings look OK, but it squeals for about 30-45 sec when cold. Can't for the life of me figure out why, but I'd just like to replace it with something newer and more reliable, so here's hoping someone might have a line on a newer replacement like the engine room blower fan from Dayton.
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 02-20-2007, 10:09 PM
palle7688's Avatar
Is it possible, as im relatively easy, to install these in earlier cars??
Are the footwells the same on my '76 and later carreras?
You might not be happier owning a Porsche, but it certainly feels so driving one
Old 02-21-2007, 06:09 AM
Yes it's possible, I did it to my '78 with good results. Sorry, I don't have link, you'll have to search, there are a couple good descriptions of the procedure on this board.
Jerry M
'78 SC
Old 02-21-2007, 06:20 AM
Jascha's Avatar
Originally posted by ianc
Hey Jascha,
.... Brushes and bearings look OK, but it squeals for about 30-45 sec when cold. Can't for the life of me figure out why, but I'd just like to replace it with something newer and more reliable, so here's hoping someone might have a line on a newer replacement like the engine room blower fan from Dayton.
ianc
The squeal you are describing is fairly universal and should have resolved after you lubricated it. The bearing (if you can call it that is quite primitive) I noticed that the screeching stopped on the bench but when reinstalled it returned.
Try repositioning the assembly such that all of the attachments are neutral and not distorting in any one direction the housing...
Q: Did anyone find a source for the brushes (engine compartment blower motor or foootwell motor type)
Old 02-21-2007, 09:39 AM
ianc's Avatar
Yes, I also noticed that, which made it very difficult to troubleshoot. when I had the motor dismounted, it made no noise, but when I reinstalled it, no matter how I tweaked and turned it, it's still noisy. Still not sure what's actually making the noise...
ianc
Old 02-21-2007, 11:29 AM
maybe grease would work better than oil. I don't remember seeing anything about an alternative motor. For the fan motor in the back at the engine several folks have found alternatives that you can make fit with a little engineering but that's completely different than the footwell blowers. You'll have to let us know if you find anything for the footwell blowers.
Old 02-21-2007, 03:48 PM
ianc's Avatar
I think that's the purpose of this thread.
ianc
Old 02-21-2007, 05:42 PM
Jascha's Avatar
ianc:
In these type of applications I tend to use Wurth HHS 2000 which you can spray and it sets into a high temperature grease. This magic happens as the solvent evaporates (very quickly), resulting in a high adhesive force between the lubricant and metal surface (motor shaft). It is especially resistant to high pressures
A must have (our Host may carry it)
Jascha
1989 911
1996 993 ('Go Navy')
1984 911 ('Go Pelican')
Old 02-21-2007, 05:51 PM
FenderGuy's Avatar
Jerry M
'78 SC
Jerry
Do you have any photos?
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 10-11-2007, 08:34 PM
jhubs's Avatar
Did all that oil and grease and repair stuff, but those footwell motors were just 20 years old and the bearings were shot. $144.00 X2 from our host...they purrrr like German kittens!
Jerry
1995 993 Carrera, Guards Red Coupe (current)
1987 911 Carrera, Marine Blau Metallic (06-08) Gone but...
1965 Yellow Mustang Convertible (65-05)
__________________________________________
It is always a good idea to keep the pointy end going forward as much as possible.
Old 10-11-2007, 08:52 PM
Originally Posted by FenderGuy View Post
Jerry
Sorry, no photos, but here's a link that may help (I didn't have enlarge any openings and the carpet footwell panels covered the blowers with no problems).
Footwell blowers in a 78SC
Jerry M
'78 SC
Old 10-12-2007, 06:20 AM
