-   -   Grease Gun/Setup for ER PolyBronze Bushings (http://forums.pelicanparts.com/porsche-911-technical-forum/331519-grease-gun-setup-er-polybronze-bushings.html)
cab83_750 02-20-2007 08:36 PM
I seem to be having an issue greasing the rear PB bushings. Greasing the inner nipple (the one closest to the car body) is impossible due to lack of clearance. Luckily (or unluckily), my 30 year old hand-cranked grease gun died on me after 5 minutes of attempt; I think the rubber stem finally cracked. BTW, my dead unit is the 'needle' type.
What kind of grease gun/setup do you guys have to access the inner nipple?
Thanks a mucho.
don911 02-20-2007 09:22 PM
I'm just using a gun with a flex line. Is your fitting centered in the bushing? One of mine isn't centered as well as it could be so that one is a little tight but I was still able to hook up to it.
scottb 02-20-2007 10:24 PM
Have you tried a right angle fitting for your grease gun?
http://forums.pelicanparts.com/uploa...1172042626.gif
Or, how about a swivel fitting?
http://forums.pelicanparts.com/uploa...1172042649.gif
Both are available at Harbor Freight for just a few bucks. Kragen.com has them also, but they're more expensive.
Combined with a flexible hose, one of these might solve your problem.
Good luck!
Johnb911 02-20-2007 10:47 PM
Could someone list all the grease points on an SC.
KFC911 02-21-2007 04:28 AM
One of my rear nipples gave me a bit of trouble and I found that the right angle fitting (on a flex line) worked better in my situation.
swa911 02-21-2007 05:37 AM
Use a flush type grease fitting on your gun. It is a little tricky till you get the hang of it. Just put the tip of the fitting in the end of the zerk and press hard. It works.
GothingNC 02-21-2007 08:17 AM
Is there a preferred grease to use?
I have Poly bushings up front and Neatrix for the rears.
Thanks !:)
KFC911 02-21-2007 08:41 AM
Thanks !:)
I use Redline on my poly-bronze bearings (it's the grease I keep on hand), but any good grease should suffice imo.
cbeers 02-21-2007 09:13 AM
You can also attach a needle fitting to your gun and then slip the needle inside of the zirk fitting. A little on the messy side, but at least it gets in there.
Scott, thanks for the info on tips. For what it's worth, I have been into at least three different Kragens asking about alternate fittings and they all said they had no clue. YMMV of course.
HF here I come!
-Chris
TWork 02-21-2007 09:26 AM
Interesting. I'm having the exact same problem. The car's not on the road yet so I have some time. I'll have to pick up a right hand fitting.
pmajka 02-21-2007 09:42 AM
Poly Bronze on a street car?
Yes or No
KFC911 02-21-2007 09:47 AM
Yes, absolutely!
goat 02-21-2007 09:56 AM
Yes or No
Yes!
I don't know what grease gun I have but it is very old. May have to try the swivel fitting myself.
cab83_750 02-21-2007 03:57 PM
Scott,
Do you have the PB bushings? I am soliciting for 'actual experiences.' Those fittings are also at PepBoys. I want to make sure that what I buy will work.
I'll stop by HF so that if it does not work, it would be less $$ wasted.
cab83_750 02-21-2007 03:59 PM
Keith,
The right-angle one was the one I was eyeing as the best candidate. Did you have clearance issue? Can it be cut shorter, if needed?
Danimal16 02-22-2007 07:54 AM
I wonder if Chuck has any insight on this one? If anyone can figure it out, well rumor has it he's come up with a few inovations???
Chuck, where are you?
Chuck Moreland 02-22-2007 09:52 AM
I use a regular, straight, rigid gun tip. I did touch the side of the tip to a grinder to make it easier to fit next to the cover plate - but that issue was specific to the thickness of my tip.
I have two grease guns. A man-size one that takes the big grease cartridges, and a smaller one that most home mechanics would use.
I use the smaller one and don't have any problems getting the gun in place.
Danimal16 02-22-2007 09:54 AM
Forgive me, but I can't resist, SO SIZE DOES MATTER!
Quicksilver 02-22-2007 10:40 AM
I use a plain straight grease gun for mine. Do you have a picture? I'm wondering if your zerks could have been placed better or not. (I guess by now that the point is moot...)
Craig 930 RS 02-22-2007 10:56 AM
Chuck -
Related to this - my A-arm (front, of course) nipples have self-rotated upwards to the point where I cannot get any grease gun on them.
What is the proper way to remedy this?
