G50 slave cylinder
I've asked for advise here before regarding inability to shift. As a result I replaced the Porsche slave (0.95" diameter) with a CNC slave (7/8" diameter). The master has a 3/4" diameter piston. The pedal (5.5 to 1 ratio) is rock hard - too hard to drive - and only moves the clutch fork about 3/8". Using a bracket and a threaded rod, I know that the fork has to move at least 5/8" to disengage the clutch.
There are no obstructions in the lines as the fluid flows freely with the slave bleeder open. The master is from a Mini and stands upright so Porsche master will not fit.
I am wondering if anyone has converted to mechanical linkage.
Any ideas would be greatly appreciated.
Thanks.
Old 02-21-2007, 12:02 PM
Diss Member
Quicksilver's Avatar
I would suspect that the throwout shaft is binding because of inadequate lubrication. You can't just grease it. It requires a special lubricant. It can get so it will only move so far. There is no reason to change the stock hydraulic ratio because the stock setup (when working correctly) has a very low effort pedal.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 02-21-2007, 12:53 PM
buttjoint's Avatar
How many miles on the car? Sounds like a typical g50 update is in order. Try g50 update in the search function
Old 02-21-2007, 02:20 PM
Everthing is brand new. Can I lubricate the shaft in place through the whole in the bell housing. What type of lubrication is recommended?
Thanks for taking the time to answer.
Old 02-21-2007, 03:54 PM
