-   -   MFI to Weber conversion II - SSI question (http://forums.pelicanparts.com/porsche-911-technical-forum/331860-mfi-weber-conversion-ii-ssi-question.html)
DavidPorter 02-22-2007 04:53 PM
My left heat exchanger has the pipe to feed hot air to the intake. What is the best way to block it off? I assume that is desirable for maximum heating.
Thanks.
Early_S_Man 02-23-2007 12:54 AM
David,
Yes, the hole in the sheet metal needs to be closed off ...
I use HVAC 2" wide aluminum tape on both sides for strength. Cross the patches, then spray with some flat black paint.
