Question Umm which is which
This isn't for my 911 but for another car. Battery was replaced but which cable terminal is positive+ and which is negative-?? Both are black. One is a little thicker than the other. I just don't want to fry the electricals.
Old 02-26-2007, 07:22 PM
Zeke's Avatar
did you look for the + and - ?? fat is +
Old 02-26-2007, 07:51 PM
The one that bolts to the frame of the car is negative unless it's some old British car.
Old 02-26-2007, 08:05 PM
Make Bruins Great Again
Por_sha911's Avatar
When in doubt, buy a $4 voltmeter at Harbor Freight and test the battery that way.
Joe
Old 02-26-2007, 08:27 PM
I figured the fatter cable was the positive+. Just needed a second opinion. Thx!
Old 02-27-2007, 05:42 AM
Be careful..... as stated, it should be pretty easy to see the 9"-14" length of NEGATIVE cable running from a connection on the body to the NEGATIVE terminal on the battery.... should CONFIRM it fairly well !!!
-Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-27-2007, 06:12 AM
