-   -   Restoration project problems (http://forums.pelicanparts.com/porsche-911-technical-forum/33201-restoration-project-problems.html)
bjola 12-13-2000 03:10 AM
Hi Porscheans,
During the rebuild of my -65 911 I have run ito a little problem.
Looking in the workshop manual (in the body part, diagram C97a/B97a) the distance between the forward and rear attachmentpoints for the front suspension is indicated to 497.3 mm. On my car the distance is more like 487.3 mm!
I have come across incorrect information in the manual before but my car has been repaired in this area so I don't know which to use.
For the moment I need this distance to complete the repair rig to get everything straight and within tolerances when I start the actual "welding in new panels" part of the restoration.
It would be most appreciated if someone could confirm the correct distance or measure on a car and give me an indication to what the distance should be. The measure should be between the center of the outer/rear bolt (there are 3) on the forward attachment and the center of the bolt that holds the front suspension sub frame to the body.
Holiday Greetings from a warm and snowfree Sweden. Guess Santa have to use his car (Porsche?) this X-mas.
Bjorn Larsson
Nickshu 12-13-2000 07:25 AM
I don't have a car old enough to accurately measure, but I know from reading that the wheelbase was extended sometime after 65, I think 67 or 68, but Im not sure. Sorry I couldnt be of more help.
Nick.
__________
Nick Shumaker
1982 911SC Coupe
65-911 12-15-2000 05:50 PM
I have a 65 911...
Let me know what measurement you need and I will check it on mine..
Bruce
