touch up paint,what kind of brush
I have some of the paint left over from a respray done about ten years ago.I would like to dab some here and there to cover up some of the many tiny pencil tip sized chips I have under the bonnet and on the bonnet.What kind of brush or tip should I use,and has anyone had any success in doing this before.Other than the few chips that I have the paint is probably an 8 or 8.5 out of ten so I don't need a total respray or anything.Any replies would be welcome.
Old 07-23-2007, 07:44 AM
Super_Dave_D's Avatar
Go to your local hobby shop and pick up some brushes - 00 and 000 size will do you fine.
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 07-23-2007, 08:18 AM
Best tip I ever got for touching up stone chips was to use either a match stick or a cocktail stick instead of a brush. Brushes usually apply too much paint, whereas using the end of the matchstick/cocktail stick enables you to build up relatively thin, accuartely placed layers.
Try it, it works
Ian
Old 07-23-2007, 01:15 PM
kplackmeyer's Avatar
+1 on matchstick...but I have always used paper matches. if it's too wide, you can trim it with a razor.
Kerry Plackmeyer
1975 911s
Old 07-23-2007, 01:19 PM
Type911's Avatar
Brushes hold too much paint for most paint chips.
Like others have said, take a match..cut it at an angle.
With a very small sharp tip you can now touch up any chip no matter what the size.
Great color! Is it a simple name like light blue, or ??
2021 Spyder
2019 Carrera T
2007 911 GT3
1973 911E
RGruppe #295
Old 07-23-2007, 01:52 PM
PSJoyce's Avatar
I've had pretty good luck with Langka (www.langka.com) to remove the "blob" after a touch up
Paul
1985 911 Carrera
Moss Green Metallic
Steve Wong Chip, WEVO shifter & PSJ, Kuehl Air Conditioning
Old 07-23-2007, 02:31 PM
Its Gulf Blue
Old 07-23-2007, 02:39 PM
Most 'supplied brushs' holds too much paint and gives you no control. A 000 tip brush is WAY smaller than a match and gives you greater control. I guess the priciple is the same - go very small and build up as needed.
2015 Audi S3
Old 07-23-2007, 04:45 PM
+1 paper matchstick. Bend the paper match back and forth several times, then tear it out of the book. There will be several small fibers that you can fluff up, then trim the match to the right width or sharpness. It hold the paint just right so that you can use several applications to build up the paint to fill in the chip.
Old 07-23-2007, 05:22 PM
Monza_dh's Avatar
wow, perfect timing on this
my "new to me" deck lid is at the shop getting painted and I will have extra left over. what about clear coat on top of the small touch up spots? Is it recommended?
I've seen kits on a few sites with touch-up pens and a clear coat pen to go over the newly applied paint. Is this overkill for a rock chip??
BTW, Nice color on the car!
$35 and a six pack to my name.....
'88 Diamond Blue Carrera CE 3.4-SOLD
Old 07-24-2007, 02:35 PM
