Help on torque wrench settings
Trying to torque down cylinder head/pistons
and cam tower nuts. Anyone have the torque specs on a 2.7? BTW, I found out that the cams used on this 2.7 bears the marking on the cam tip: 930 148.10. Anyone know why this setup is used? How can one distinguish Dilavar studs from stock ones? Im trying to decide whether to purchase this motor: 2.7, rebuilt 12,500 miles ago, time sert, dilavar studs in question (owner had it rebuilt and could not remember), new Mahle pistons/cyl.,new valves/guides, turbo valve covers, carrera tensioners, pro headwork and ported to 36/35, 930 cams??. Long block selling for $1200. |
Looks like a job for Mr. Hall. While you're at it, Warren, I have a question: Is 12 inch-pounds the same as one foot-pound?
------------------ '83 SC |
Bruce Anderson says Dilivar is non-magnetic, so check the lower studs with a magnet. Dilivar studs get 29 lb-ft, regular steel get 25 lb-ft. Camshaft housing nuts get 18 lb-ft.
And, yes, 12 lb-in equals 1 lb-ft! ------------------ Warren Hall 1973 911S Targa |
| All times are GMT -8. The time now is 11:16 AM. |
