What flywheel do i need?
For the 3.6L conversion into an 82 SC, I know I need a new fly wheel, but which one? And why do I need it? Is it aftermarket or is at a factory part from a differant car?
Old 02-27-2007, 02:25 AM
Call Patrick Motorsport and get the conversion flywheel for the 915 tranny. You need the new flywheel with toothed outer rim for rpm sensor/timing position in order for the 3.6 DME to function. Be sure to get a ring gear for the flywheel. When I did mine, I read all the threads re the 3.6 conversion and never saw the ring gear issue. I ended up putting the engine in and out of the car several times before all was right. Also, get the right length clutch bolts.
Old 02-27-2007, 03:43 AM
