Is ball joint removal DIY job?
I am looking at my 101 Projects book and Bentley manual and the job seems pretty straightforward. I have ordered the special Porsche tool to remove the slotted nuts under the control arms and a set of replacementsfrom our host.
Then I came across a $300 press tool on Pelican suggested for pressing the ball joint into the steering knuckle and now I am not so sure. Just FYI, I am doing this as part of a project to deal with an annoying vibration in my steering wheel from 70-75mph. I have eliminated the wheel/imbalance since I have two sets of wheels. Since the ball joints have not been replaced on my 155K miles 78SC this seems to be worthwile. Any comments are appreciated. Ulrich |
I just did the ball joints on my SC. I had the a-arms out of the car for it, but it was really easy. After reading all the threads on here about how difficult it can be I was a bit scared...
You definitely want the socket that Pelican sells. I used an electric impact wrench to loosen the castle nuts with that socket - they came right off. Looks like someone who had come before me was nice enough to install those nuts with some anti-sieze. I could see how it would be really hard to get them loose if they were frozen. Order new castle nuts, retaining washers and cotter pins along with the ball joints. If the castle nuts won't come loose, use a dremel tool to cut them off. If you are replacing them with the a-arms still on the car, you need to rig up some way to hold the socket and your impact wrench tight against the ball joint castle nut from below. If you search for Muffinman's "front suspension refreshening" thread there is a picture. Edit - by far the hardest part of the job was getting the wedge pins out of the struts to release the ball joint. One came right out with minimal pounding. I had to drill the other one out - took quite a while. Don't forget to order those wedge pins (and washers and nuts) since you will very likely destroy the old ones while removing them.
'82 911SC racecar '05 WRX STi Last edited by jaydubya; 01-01-2007 at 12:34 PM.. |
The special tool for the castellated nut is best used with an impact wrench and some good leverage to hold it down on the nut. If you try to use it with a socket wrench, laying on your back, you may have trouble keeping it from slipping as I did. A monkey wrench and some swearing got it loose for me. edit spelling
Sheena is a punk rocker Suzy Is A Headbanger Heidi Is A Headcase Judy Is A Punk The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'." |
If you have trouble, use a propane torch to heat the castellated nut first. I did.
“If you want to win anything- a race, yourself, your life- you have to go a little berserk” - Dr George Sheehan. “Happiness is different from pleasure. Happiness has something to do with struggling and enduring and accomplishing.” - Dr George Sheehan. |
Home of the Whopper
I jacked up the corner I was working on, heated up the castle nut, put the impact on the castle nut, then released some pressure from the jack until a lot of weight from the car was resting on the impact gun. Make sure everything is perfectly square, then hit the trigger. Zapped right off.
To tighten, my impact couldn't get the nut tight enough. I used the jack to hold the special tool against the castle nut, then used the jack handle as an extension on the rachet. I tighten to approx really f'n tight. As others have said, the wedge pins can be the real beyotch. Have fun!
1968 912 coupe 1971 911E Targa rustbucket 1972 914 1.7 1987 924S |
It's definitely a DIY job. As 9elf said... liberal use of heat is a must.
'73 Targa |
Re: Is ball joint removal DIY job?
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
You can do it yourself. I suspect replacing them will not solve your vibration though. From what I have read, you replace ball joints so they don't break on you while you are driving. There a few posts on Pelican of what a disaster that can be.
I had my a-arms off the car, and I didn't have the tool, so I took it to John Walker and he buzzed them off for me with the tool and an impact wrench (gratis). Also buzzed on the new ones for me. Just a tip I learned the hard way: when you are beating the wedge pins out, I left the nut partially on the end of the bolt. It was much stronger than the bolt alone. The bolt just mushed up as I hit it and I almost didn't get that first one out. You also definitely need to replace the wedge pins. They are stretch bolts and shouldn't be restretched. Out of curiosity, could your vibration be coming from old tie rods or tie rod ends?
James 1969 911E Slate Grey 1981 911SC Wine Red 1997 911C4S Ocean Blue |
Here is a useful thread on installation sequencing...
http://forums.pelicanparts.com/porsche-911-technical-forum/333917-ball-joint-installation-question.html#post3142250
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
