jj4u3's Avatar
Unhappy plug fouling
I have a 1972T coupe with Weber Carbs and I was wondering if I have options
I don't have a vacuum hose and I can't keep them adjusted and keep fuel fouling the plugs?
this is strictly a daily driver and am looking for something that will start and won't give me the trouble that I am currently having
Old 02-26-2007, 06:04 PM
Early_S_Man's Avatar
Porsche Crest
What spark plugs, brand and heat range, are you currently using???
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-26-2007, 06:15 PM
jmz jmz is online now
jmz's Avatar
proper plugs in correct heat range and an MSD helped solve my fouling problem.
It took a while to find the right plugs.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 02-26-2007, 06:38 PM
jj4u3's Avatar
currently I am using Bosch super R6 585
I tried ACDelco R43XLS
Champion 415 RN9YC
My main cylinders to foul are 1 & 6
I am thinking maybe valve bushing wear but the machanic that works on my car thinks it is the Carbs
since I don't have a vacuum line he had to advance the timing and that helped but after a short time the plugs foul and I have to change them out and then it runs great for a while (a week or two)
when I cold start it it bucks and snorts and then begins to level out
close to the end it backfires while driving, loss of cylinders and have to change out those 2 plugs?
911 - 1972T
Old 02-26-2007, 08:11 PM
jj4u3's Avatar
my compression is good
my thinking is that if I was to try and find another engine and swap out I would be buying a whole new set of poblems
I am not a mechanic and can only preform simple tasks
tearing down the engine or even adjusting the carburetors is beyond my capability
911 - 1972T
Old 02-26-2007, 08:19 PM
Porsche Crest
That doesn't sound like a Bosch number I have ever seen!
Well, I suggest trying NGK BP6ES.
Check your spark plug wires for end-to-end continuity ... 3000 Ohms to 4000 Ohms resistance. They can go 'open' inside the Beru connector and cause a fouling problem.
Warren Hall, Jr.
Old 02-26-2007, 08:23 PM
