This isn't for my 911 but for another car. Battery was replaced but which cable terminal is positive+ and which is negative-?? Both are black. One is a little thicker than the other. I just don't want to fry the electricals.
did you look for the + and - ?? fat is +
The one that bolts to the frame of the car is negative unless it's some old British car.
72 Carrera RS replica, Spec 911 racer |
Make Bruins Great Again
When in doubt, buy a $4 voltmeter at Harbor Freight and test the battery that way.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
I figured the fatter cable was the positive+. Just needed a second opinion. Thx!
Be careful..... as stated, it should be pretty easy to see the 9"-14" length of NEGATIVE cable running from a connection on the body to the NEGATIVE terminal on the battery.... should CONFIRM it fairly well !!!
-Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
