Unhappy 1986 Targa - Electric Windows
I am trying to get my electric windows working again on my 1986 Targa.
I have checked the fuse up front and it appears fine. I believe this to be fuse #1. All of them looked fine, but who knows.
I also replaced all of the window switches with brand new ones from PP. No luck.
What next? Anyone have a local San Francisco mechanic I can take this car to?
Thanks in advance...
Old 02-28-2007, 10:15 PM
steve911's Avatar
I would remove the fuse, clean the contacts and replace with a new fuse. My windows stopped working and the fuse looked fine. I replaced with new and have not had a problem since.
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 02-28-2007, 10:37 PM
Thanks Steve911. I'll also assume I am checking the right fuse (fuse #1) which is closest to the front of the car.
Old 02-28-2007, 10:44 PM
slodave's Avatar
Yup. It is a 25 Amp fuse.
Old 02-28-2007, 10:48 PM
Thanks. Ordered fuse kit from PP.
Old 02-28-2007, 10:51 PM
Do you have a meter and a schematic?
Edit: Is there 12 volts on each side of that fuse you are going to replace with the door open?
When you cycle the door light switch can you feel the relay click in the trunk?
Old 02-28-2007, 11:03 PM
