88 Targa Help
I am trying to fix or adjust the drivers door on my 88 Targa so that I can fill in the gap I currently have between the top of the cut window and the targa top itself.
I have about an 1/8 of an inch and am looking for help on how to adjust the height of the door??? My mechanic said that he could do it, but it would cost about $200-300 so I am looking to try and do this myself. Any assistance would be great.
1996 Porsche 911 2013 BMW 335xi - Wifes car 2007 4Runner - 4x4 for Colorado snow Past: 1988 Venetian Blue 911 Targa, 1983 Black 930, 1984 Black 911 Coupe |
Will program for food
Do you have a Bentley manual? If not that is a good place to start. Does the door need adjusting or the window height?
Check the door and see if there is a uniform gap between the door and the body. If the gap is uniform then I would suggest first adjust the window height. You can adjust the window height by removing the door panel and playing with I think 3 adjustment allen-head bolts. One bolt is the height adjustment.
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
I have to second that.
Get the Bentley manual and it will walk you through the process. It's quite a bit of trial and error and adjust...re-adjust. Ask me how I know. |
See the following documentation provided by some other pelicanite!
http://www.dimebank.com/misc/sealing_of_911.pdf Good Luck _____________ '81 911SC Targa |
I have some info that might be helpful but I'll need an email address to sent it to.
KC 88 Guards Red Targa (sadly sold )2005 Boxster S 1st Porsche 73 914 (long gone) |
PM sent...
Once again I have about an 1/8th of an inch gap between the cut window and the targa top that creates extreme amounts of wind noise while driving on the highway.
So after reading the service document I am no closer to fixing my problem... From what I can tell I need to take the door panel off, and then there are three screws that I need to play with until I figure out which one raises and lowers the window??? Anyone on here done this that give advice on how much upward play I have in the cut window? From what I can see without removing my panel it looks to be fixed onto the dor itself...?
Anyone with any experience in adjusting the height of the cut window on their Targa or Cab?
Wash. State
I might have some info/literature that will help you. Will send it Sat. morning.
L |
The more info the better...thanks.
