questions about installing the gold emblem on 930S steering wheel
Okay, this might be a stupid question, but here goes:
I have just purchased the 930 wheel from our host. It hasn't arrived yet, but I did get the emblem in with another shipment. Upon inspection, there is a nub on the back of the emblem (I assume for affixing to a hood). THis would either need to be cut off or a hole placed in the horn pad to accommodate it.
What have others with the 930 replacement steering wheel done to affix this cloisonne to the horn pad? The tech article doesn't cover this.
Thanks,
Patrick
Old 03-02-2007, 06:16 PM
Super_Dave_D's Avatar
I didnt want to drill holes in my pad so I just cut off the post and used some 3M double tape. Some people drill the pad and use the speed nuts. Others will even route out the depth of the crest so it sits flush with the pad. Your choice.
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 03-02-2007, 06:39 PM
Thanks Dave, I'll have to think on this one..to drill or not to drill.
Old 03-02-2007, 08:34 PM
- Self Moderating -
Isn't there an emblem that is meant for the steering wheel? I have seen them advertised in Excellence magazine.
Tim
Present: 57 Intermeccanica Speedster Ivory on Brown
Past: 85 911 Carrera Coupe Silver on Black, 57 Intermeccanica Speedster White on Tan
Old 03-02-2007, 08:36 PM
I haven't seen that advertised, but here on Pelican this is the one they suggest for use with the wheel. It has the nub on the back.
Old 03-02-2007, 08:47 PM
zrdstr3's Avatar
I found a stick on emblem at the Porsche dealership and used it instead of the one I purchased from our host when I bought my wheel.
John
85 Carrera Targa
Old 03-02-2007, 09:08 PM
The one pelican sells has posts for speed nuts - I cut mine off.
2015 Audi S3
Old 03-02-2007, 09:27 PM
IIRC, all the proper badges come with a post. I drilled a hole and affixed a gold badge onto the cover. I have debated on whether to replace with the silver or painted version. Either way the hole is covered...post or not.
Warren & Ron, may you rest in Peace.
Old 03-02-2007, 10:33 PM
I cut my post off and used contact cement to affix it. Hasn't come off in 4 years.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 03-03-2007, 05:20 AM
buttjoint's Avatar
I drilled the hole and took the leather off with a heat gun and routed out the crest. Easy and looks oem
Old 03-03-2007, 05:53 AM
You could always opt for the cover with the embossed badge.....
Old 03-03-2007, 09:19 AM
