-   -   Idle Problem Solved (http://forums.pelicanparts.com/porsche-911-technical-forum/333311-idle-problem-solved.html)
sal 03-02-2007 10:16 AM
Idle Problem Solved
Wow, I solved my irregular idle problem. My 1983 911sc would idle high when warm would oscillate and surge when cold. Then sometimes would be right on where it should be. I thought the problem was the fuel system until the ignition distributor started to make noises and the idling got worse. I could detect a pattern the distributor grumblings and a surge in the engine idle. It sounded like something had got loose in the distributor and was binding with something in advance chamber of the distributor. I took the distributor apart and found a spring loose from the mechanical advance weights. I hooked it back up, re-install and the idle problem is gone! It is "ROCK STEADY" idle now! After re-install of distributor I had to adjust the ignition timing, it seems to me the last time it was adjusted it was influence by the particular position if the loose mechanical weight. I summary I think the my idle surges and irregular idle, was caused by timing advance issues-the free floating mechanical advance weight.
The next thing is where can I get the little plastic bushings used for mounting the mechanical advance springs in the distributor? Mine are gone, I ended up pinching the springs hooks to make sure they stay on.
Grady Clay 03-02-2007 10:55 AM
sal,
Thanks for posting this.
Too often we are lead astray by symptoms that indicate one system (fuel) where all systems need to be considered.
Best,
Grady
76carrera3.0 03-02-2007 12:05 PM
Dizzy parts
I just recently spent weeks phoning anybody and everybody to find the samething. I finally found out that no service parts are available. You may find a rebuilt on the self $$$$ or your next best bet is a used unit off the board and make one out of two. This is the route I went it is a heck of alot easier on your wallet.
