-   -   Source for M5 x 105 alternator through bolts (http://forums.pelicanparts.com/porsche-911-technical-forum/333318-source-m5-x-105-alternator-through-bolts.html)
preston_brown 03-02-2007 11:01 AM
As I have noted several others have done here in the past, I managed to mess up the long skinny bolts that tie the front and back of the alternator together while I was removing it from the fan shroud. I have measured these bolts, and they are M5x105mm. This is on a 1987 Carrera, the measurements could be different for different types of alternators from other model years.
Does anyone have an internet source or other source I could call to get these bolts? I have tried locally by calling alternator/generator shops but have struck out. Google searches on that size of bolt have only yielded some part sheets for parts for some hydraulic pump, and McMaster doesn't have M5 bolts (cap head screws) that are longer than about 60mm.
I would really appreciate any help on this. My alternator doesn't need a rebuild yet, and I don't want to buy a new or rebuilt one.
Early_S_Man 03-02-2007 11:29 AM
Preston,
I forgot that it needed to be threaded full length, so ...
Metric & Multistandard has DIN 975 threaded rod, property class 10.9 or stainless, available by the meter, here:
http://www.metricmcc.com/catalog/Ch1/1-114.pdf
mthomas58 03-02-2007 11:39 AM
Subscribing with great interest.....I snapped a couple of mine while working on my fan polishing project. Thought I'd move on to the shroud. After snapping two bolts I quit.
Scott Clarke 03-02-2007 12:16 PM
Give up! Used is the only way I got any. Warren is correct in that you can get a bolt in that length, but the problem is that, inevitably, the shank won't have enough threads. If you post a WTB ad in the classifieds, some generous soul may sell you some used ones. I did this and had good luck.
-Scott
mthomas58 03-02-2007 12:50 PM
Preston, I just spoke to Richard at dcAutomotive (dismantler in Rocky Mount NC). He said if you shipped him one of your broken bolts with some thread left on it, he should be able to match it for you. Let us know if you have any luck. I have not tried yet locally but will probable end up back at dc.
http://www.dcautomotive.com/contact.htm
800-579-2410
BTW, since I have not had mine disassembled what the bolts screw into........Parts diagrams show a washer and nut.....but, if that's the case...how was I able to get those I didn't break back in? Mystery to me.
Early_S_Man 03-02-2007 01:09 PM
Guys,
I just edited my earlier post to show threaded rod rather than Allen bolts ...
The rear half of the alternator housing is threaded ... that is why you need bolts with a long threaded area. Threaded rod should work fine ... just install a washer and hex nut where the head of the screw was originally! I suggest anti-sieze compound on any screw or rod during reassembly.
Jeff Alton 03-02-2007 02:49 PM
The threaded rod is available locally here if anyone needs some.
Cheers
preston_brown 03-06-2007 07:07 AM
I just ordered some "M5x105" bolts that are spare parts for some sort of pneumatic device from somewhere on the west coast. I have *no idea* if they are really the right sort of part or not, but they were cheap, so we'll find out. I'll let people know if they are the right stuff.
defcon65 03-06-2007 01:53 PM
Take one to a local alternator/starter rebuilder and see what they have in their junk pile. They are not that uncommon...
