what color to paint my tank??
well after many hours of sanding stripping priming, i am now coming to the point on what color to paint my tank? im thinkng a dark silver gray maybe slate gray? i dont wanna do body color bc i am already in process of redoing the paint under the hood the body color and want some contrast
![]() and a photo of the color of the car ![]() thanks and wow this was a project in a half up to this point cheers
86' 911 coupe |
I've always been impressed with tank restorations that are painted like the OEM tank. Go Wurth young man Go Wurth
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
Great question! I am at the same point on my '70 and do not know what color the tank was originally. I have gone to great lengths to get the trunk right after the pan replacement, but do not know what color the tank should be. Mine was a mess when I bought the car.
David Nolen |
My vote is for OEM. Can't go wrong.
87 Carrera Cab GP White 01 740i Sport 03 Honda Odyssey |
What is the OEM color?
David Nolen |
Back in New England!
My vote is for a shinner look than OEM...satin grey.
-Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
I used Rustoleum industrial grey. It is in their industrial line of paints. Good color and looks fairly factory.
John Brasfield 91 C2 78 SC For sale 76 3.6 68 Datsun 2000 Mr. Magoo, 02 330ci |
cycling has-been
I did a couple of base coats with rubberized pickup bed liner for texture, then an engine enamel in light industrial gray. looks oem and didn't cost an arm & a leg.
Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
I re-shot mine with the Wurth stuff. It looks great.
1976 911/S/SC/BASTARD Mid9 Member #12 |
tell us more about the effort involved. Did you also refurb the inside?
'83 SC |
what brand was the light industrial gray?
was it a rattle can?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Neil Peart Fan
Wurth is the way to go to give the texture of OEM
