Pulley Seal O-Ring Reaplacement
I have a pretty major oil leak around the pulley. Iknow I can replace the seal pretty easily, but it looks to be coming from around that whereI beleive the o-ring is. Can I pull the end off and replace the o-ring too?
John
1985.5 944 GTS |
No
The o-ring goes on before you mate the case halves. Those leeks seem about impossible to fix unless you split the case. -Andy
72 Carrera RS replica, Spec 911 racer |
Wonderful. Any ideas? Quick fixes?
1985.5 944 GTS |
North Coast, it sounds like you have a leak at the number 8 nose bearing. I had success in this nose bearing leak thread.
It is a fixable taks, but it will take a little time. PM me if you get stuck. Mine is leak free since the repair. Good luck, David
99 996 C4 11 Panamera 4S 83 SC Targa converted to a 964 cab (sold) 67 912 (sold) 58 Karmann Ghia choptop (traded for the 912) |
