Honey Badger
theFONZ's Avatar
Essential 911 tools
I want to put together a small toolkit to keep in the trunk. Does anyone have a list of tools they couldn't live without? What size wrenches and sockets should I have. What else should I keep in it? Which type of whiskey in little airline bottles should be in it?
1978 911SC
1953 Piper PA-18A
USAF EOmfD
Old 01-16-2006, 04:33 PM
Scott R's Avatar
Two 13mm open ends for when my shift linkage slips in rush hour traffic.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-16-2006, 04:48 PM
Factory tool kit plus a complete set of open end/box combination metric wrenches. That will usually get you to a shop where there are sockets and air tools.
Mike B.
'72 911E Coupe
Early "S" #1065
Old 01-16-2006, 04:56 PM
DW SD's Avatar
10mm combination wrenches and sockets. flat head screw driver, philips head screw driver. Small set of allens, metric of course. Add a wire cutters, crimpers and some connectors for emergency repairs. Maybe even a few feet of wire.
1971 RSR - interpretation
Old 01-16-2006, 05:01 PM
abit off center
cgarr's Avatar
I find a good metric crecent wrench and some extra cash should about covers it!
______________________
Craig
G2Performance
Old 01-16-2006, 05:08 PM
durn for'ner
livi's Avatar
Cell phone.
Markus
Resident Fluffer
Carrera '85
Old 01-16-2006, 05:15 PM
Zeke's Avatar
Search traveling. We did a few threads on what to take on a trip. Of course, the cell phone was on the list many times over.
I bought a tool kit at Lowe's that was labeled "Auto Tools." Mostly a bunch of fair quality tools and a few surprises. Like a couple of hose clamps and a few fuses. Not a lot of anything, but enough to supplement the factory tool kit. Yes, it has metric. I take this to the track with me along with some specialty tools that I have conjured up a list for. If it gets any worse than what I can fix with this set up, .....cell phone.
Or look for Tyson....
Old 01-16-2006, 05:22 PM
Non Compos Mentis
10mm, 13mm, and 19mm, and you can almost disassemble the entire car. Add a screwdriver and some duct tape, and you'll probably be fine.
Old 01-16-2006, 05:32 PM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
That`s all you need
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 01-16-2006, 05:33 PM
gduke's Avatar
don't forget fuses and maybe a few relays.
1985 911 Carerra Cab 3.6l
1998 Dodge Ram
2004 Toyota Tundra Quad Cab
Old 01-16-2006, 05:34 PM
Honey Badger
theFONZ's Avatar
What relays and fuses are good to have?
I have the factory tool kit minus the wrenches.
OK so:
8, 9, 10, 13, 15, 17, 19 sockets and wrenches
multibit screwdriver
set of metric allen wrenches
wire cutter, connectors, wire
small and large crescent wrenches
a couple different kinds of pliers
a foot of fuel line
misc clamps
duct tape
zip ties
Jack Daniels
How's that sound?
1978 911SC
1953 Piper PA-18A
USAF EOmfD
Old 01-16-2006, 06:26 PM
pwd72s's Avatar
Good point. The two sizes you'll most likely need to "double up"
are 13 & 10mm. I'd suggest that, plus sizes 7 thru 19 combo wrenches as a base starting point.
Old 01-16-2006, 06:44 PM
Honey Badger
theFONZ's Avatar
Does the 911 have any 11, 12, 14, 16, 18mm bolts? I figured if it doesn't have them why put them in my emergency tool kit.
1978 911SC
1953 Piper PA-18A
USAF EOmfD
Old 01-16-2006, 06:57 PM
The factory tool kit is amazingly good. You can do a ton of work with it. I never needed anything else. I figure anything that I can't do with the factory tool kit I need to do someplace else. Just make sure it's complete. Like Zeke said, check for other threads on what to take when you travel. There have been some extensive threads for what to carry when you travel that would include spares, etc...
Only tangentially related, something to have at home
KD Tools 12pc Metric GearWrench Flex Head Ratcheting Combination Wrench Set (8mm to 19mm)
The KD gearwrenches are great, you get fairly fine teeth, and the flex heads can be really helpful. The only time you would want a regular combination wrench might be in a really, really tight space.
Old 01-16-2006, 07:03 PM
fred cook's Avatar
Cool Basic Tool Kit...
WD40 or Blaster
Duc Tape
Coat Hanger Wire
If it moves and should not, use the Duc Tape and Coat Hanger wire to anchor in place.
If it does not move but should, spray liberally with the WD40 or
Blaster!
Good luck!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 01-16-2006, 07:16 PM
Zeke's Avatar
One more: Some metric Allen wrenches. If you have CIS, then from 3mm on up. You won't use them all, but they don't take up much space. You'll soon learn which you can leave home.
Old 01-18-2006, 09:12 AM
Breeang's Avatar
AAA and a cell phone
1957 KR 200 Messerschmitt Bubble Car 3 wheeler-my first rear engined air cooled German car,alas long gone!.
1977 911S 2.7 to spend money on
2006 Tundra for acting grownup
Old 01-18-2006, 10:20 AM
Early_S_Man's Avatar
Fonz,
With your EFI ... I suggest a good DMM with port for logging to a PC, and a portable scope with PC cable and screen plotting capability wouldn't hurt, either! Also, a CMOS-capable logic probe would be good for troubleshooting, too.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-18-2006, 10:27 AM
wcc wcc is offline
wcc's Avatar
Vice Grips have come in handy a couple times for me on the road.
Bill
997.2
Old 01-18-2006, 10:35 AM
Nitrometano's Avatar
mini air compressor, battery post cleaning device, jumper cables, extra ignition coil, cap & rotor, alternator v-belt.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
