alf alf is offline
alf's Avatar
993, 996, 997 Power to Weight Ratio?
Anyone have the power to weight ratios for the later generation standard Carrera 2s?
88 Carrera Coupe
Pelican Since 2002
All Zing, No Bling. ok, maybe a little bling.
The Roach
Old 03-06-2007, 06:46 PM
450knotOffice's Avatar
Well, the 2000 has a LISTED weight of 2920 pounds and 300 hp, so officially it has a power to weight ratio of 9.68 lb/hp. however, depending on options, the weight can be significantly higher. My lightly optioned 2000 996 C2 actually weighs 3035 pounds, empty (weighed on known accurate scales), so my car has a power to weight ratio of 10.1 lb/hp.
The listed weight of the later 996 was at least 2960 pounds and it had 320 hp for a ratio of 9.25 lb/hp.
The 997 (non-S) has a listed weight of 3070 lbs and has the same 320 hp as the later 996, so it has a ratio of 9.6 lb/hp.
The 997S has a listed weight of 3125 pounds and has 355 hp, so it has a ratio of 8.8 lb/hp
Remember, actual weights will almost certainly be a bit higher than listed weights (mine is 115 pounds heavier). So take these numbers with a slight grain of salt.
Old 03-06-2007, 10:41 PM
