jhubs's Avatar
Water leaks!!! Help!!
I am redoing the interioof my 87 911 coupe
Interior project on my 87 911
And, I was advised to look for water leaks before I installed the new carpet.
Well, I sat inside while my neighbor sprayed the lower doors and worked his way up. Here are the 5 areas that leak...
Lower rear corners of the back window.
Top edge of both front windows at the upper corners.
And when he sprayed the front vent on the hood under the Window shield wipers, water dripped on the inside next to the heater pipe and onto the floor on the passenger side.
Any suggestions????????
Jerry
1995 993 Carrera, Guards Red Coupe (current)
1987 911 Carrera, Marine Blau Metallic (06-08) Gone but...
1965 Yellow Mustang Convertible (65-05)
__________________________________________
It is always a good idea to keep the pointy end going forward as much as possible.
Old 03-05-2007, 07:55 PM
Won Won is offline
Won's Avatar
The fresh air blower in the trunk has a drain that connects to a plastic hose which eventually drains the water down the bottom of the car. Make sure the hose is connected to the blower, and the seal between the blower and air vent is good.
83 911SC Targa
Everything I say is my personal opinion, and has nothing to do with my team.
Old 03-05-2007, 08:29 PM
jhubs's Avatar
Thanks Won!
Does anyone know if I will have to take out the rear window and have a new seal put around it or can I place some sealant under the curent seal? I think I know the answer.....
Jerry
Old 03-05-2007, 08:41 PM
the the is offline
There typically isn't sealer used on the rear window.
Although there's no harm in giving it a try, if it doesn't work, your really no worse off than you were before (other than a bit more cleanup when you take out the window to replace the seal).
As far as the other seals, like the side door seals, careful with spraying them with a hose. They are designed to stop rain coming from the above, not water shot out horizontally from a hose.
As far are replacing window seals, do a search, there have been a few threads on it.
Old 03-05-2007, 08:44 PM
jhubs's Avatar
Bump
Old 03-06-2007, 05:03 PM
randywebb's Avatar
The cheapo windshield repair guys will come around and squirt stuff under your glass for $40. But painters hate it (silicone) and it is said to be just a stop gap measure.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 03-06-2007, 06:18 PM
Richard Burns's Avatar
With the rear window corners is it leaking between the glass and rubber seal or is it coming in elswhere between the rubber seal and body?
The best way to check is to forget the hose and fill the corner area with water from a glass and wait to see if it is actually at the corner it may have come in under pressure somewhere else and the corner being the lowest point is where it would appear to be leaking.
If it's between the glass and rubber you can use a sealant but you need one that doesn't set usually a bituminous type your local windscreen fitter would probably supply some for you.In the future if you need to replace the glass you will need a new rubber surround.
Life is not a journey to the grave with a pretty and well preserved body but to skid in sideways, used and worn out saying " What a trip!
Old 03-06-2007, 06:53 PM
jhubs's Avatar
Richard, THANKS!
I just went out and poured water in the rubber seal and window corners of the window and no leaks from that.
Then I poured water on the seal between the rubber seal and the body, no leaks.
I worked my way up the window sides and no leaks.
all along the top and no leaks.
When I poured water in the vent at the top of the window I got leaks that showed up at the bottom corners of the window inside.
Now what?
Jerry
Old 03-06-2007, 07:17 PM
Jerry,
I have never had water sprayed or poured in this opening but have been out in driving rain and never had a leak from this area. I will see if I can get an exploded view of the rear vent to see if there are any drain tubes.
You may get a reply from one of the Pelicans that have removed the headlining which would show up any drain tubes.
Old 03-07-2007, 12:56 AM
