Which hard oil line for Carrera tensioner upgrade?
I bought a partial set off the board and need hard lines from cam lines to the tensioners. Pelican has two different lines for the left side:
930-107-347-02-M20 Oil Pipe to Feed Carrera Pressure-Fed Tensioner, left, 911 (1984-89) (from engine 64D3717) Brand: Cohline $13.25 and 930-107-347-06-M20 Oil Pipe to Feed Carrera Pressure-Fed Tensioner, left, 911 (1984-89) Brand: Cohline $14.25 I understand engine 64D3717 and up simply means 3.2L. Which one of these should I use? My engine is US spec 3.0L with a Carrera case (late 83) and the part number on the tensioner appears to be 930-105-947-4R.
83 911SC Targa Everything I say is my personal opinion, and has nothing to do with my team. |
