-   -   Need some Help (http://forums.pelicanparts.com/porsche-911-technical-forum/334522-need-some-help.html)
bruni911 03-08-2007 04:11 PM
Need some Help
Well i just installed the front oil cooler scoop that goes where the light is in the bumper. My question is what do i do with the light, meaning the wiring. do i cut it or will it screw up all the other lights? Next is i installed solid Tanny mounts, i heard this is a bad idea, meaning lots of noise and vibration is this true. Thanks so much for your time.
Grady Clay 03-08-2007 05:10 PM
No problem. On earlier cars (pre- ’69?) it will effect the turn signal. The solution is to attach a bare bulb somewhere insulated.
I haven’t herd of a problem. I would chose to leave the engine mounts soft rubber.
Best,
Grady
