Ove Ove is offline
911 driver
Ove's Avatar
Arrow Anyone have pictures of the inside of a CIS fuel tank?
Im curious about the sump and the baffles that prevent the fuel from sloshing and splashing around in the tank.
Id like to see what it looks like in there without cutting up my own tank
It looks like I have a fuel delivery problem and I think its caused by dirt and rust from the fuel tank.
I have changed the filter in the engine bay and will take a look at the screen filter in the fuel tank this weekend.
There are lots of threads on the subject, but I couldnt find one with pictures of the tank internals.
Ove
'77 911S targa
Old 03-09-2007, 01:11 AM
Remove the fuel level sender, get a small flash light and look in!
Old 03-09-2007, 03:51 AM
Ove Ove is offline
911 driver
Ove's Avatar
I've already done that.
I have also done a search here on the BBS, but found no pictures.
Here are some drawings and a description posted by Grady Clay in this thread: I need the Greatest Minds of the Planet on this 73.5 issue.
" Dr. Ing. h.c. F. Porsche A.G.
1 Fuel tank
2 Whirl pot
3 Baffle plates
4 Fuel filter (screen)
5 Return lines
6 Admission line (supply)
7 Filter screw
8 Admission holes
The bottom of the fuel tank is provided with a spiral
whirl pot (2), incorporating a [screen] filter (4). The
fuel, being conveyed into the whirl pot by the fuel
pump via the pressure valve of the fuel metering
distributor and the return lines, is set into spiral
movement and is taken in again by the pump via
the [screen] filter (4) and the admission lines. The
whirl pot (2) is flanked by baffle plates, which are
perforated to let the fuel enter the whirl pot by means
of injector-type admission holes (8).
The system prevents air from being taken in which
would lead to misfirings of the CIS engine.
Ove
'77 911S targa
Old 03-09-2007, 04:42 PM
Senior Member
Early_S_Man's Avatar
Porsche Crest
Ove,
This thread had [at one time] the pics you are looking for ...
1973 911-T (CIS) Fuel Tank Exposed
Perhaps you could PM or email the originator for the missing pics.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 03-09-2007, 04:56 PM
Ove Ove is offline
911 driver
Ove's Avatar
Warren,
I have sent a PM to Paulo who posted the pictures. Thanks for your suggestion
Ove
'77 911S targa
Old 03-09-2007, 05:12 PM
From deep in the Pelican Parts 911 archives:
Old 03-09-2007, 05:25 PM
HarryD's Avatar
Originally posted by Early_S_Man
Ove,
Warren,
Here are those pictures. I replaced the spaces with a %20 to get them to come up.
Harry
1973.5 911T Targa - "Smokey"
2003 BMW Z4 3.0i
2009 MB C300
Old 03-09-2007, 07:00 PM
Ove Ove is offline
911 driver
Ove's Avatar
Ove
'77 911S targa
Old 03-09-2007, 09:57 PM
Tsunamiboy's Avatar
This is a little off topic but I will tell my tail since it is somewhat related. I just had a SC gas tank reconditioned. It ended up to be quite a big deal. I thought they would chemicaly clean it and that would be it. They cut a good sized hole to epoxy coat the inside and reweld the baffold. It turned out OK but purchasing a used tank and having it reconditioned cost more than NEW.
Performance Products sells a NEW reproduction for just a little over $400. I will go that way if the need rises in the future
Tsunamiboy
1979 911 SC (3.2L)
1997 Boxster 986
Old 03-09-2007, 10:02 PM
(the shotguns)
berettafan's Avatar
so the center of that orange thing is where the big drain plug fits in? that would explain the screen on the drain plug i guess.
it appears on my tank (just back from being boiled) that the plastic swirly thingy is broken. not only that but the lid my have come off...
how necessary is this plastic thingy and has anybody sourced a replacement?
final question: how big a deal is it to cut a hole in the tank and then reweld it shut?
Old 05-11-2007, 10:49 AM
T77911S's Avatar
ove or berettafan, did you get your tanks fixed? i am having problems with mine and would like to what you did.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 01-10-2008, 07:01 AM
(the shotguns)
berettafan's Avatar
took the tank to a Renu franchise and they removed the old swirl pot and replaced with what i THINK was a coffee can.
Old 01-10-2008, 06:10 PM
Tsunamiboy's Avatar
I spent $250 for a good used tank and $350 to have it reconditions/cleaned. I wish I would have just purchased a new reproduction
http://www.***************/productpage.aspx?pid=109223&cid=10&sid=232
Tsunamiboy
1979 911 SC (3.2L)
1997 Boxster 986
Old 01-10-2008, 06:35 PM
