kide's Avatar
Gas smell when heater on (gone), then wet spot near distributor appeared
Hello all,
I smelled gas when I turned the heater on a few days ago, and checked along the fuel lines after seeing some threads here. I could not find leaks, or replicate the smell after that. I will bring in the car to a shop anyway, though.
So, now the smell is gone, but I found a wet spot near the distributor. Please see pic - it is along the edge, indicated by the yellow oval. It doesn't smell like gas (I suppose if it were gas, it should have been evaporated). Is it oil? If it is oil, where could it be coming from?
Thanks!
Old 02-19-2007, 03:51 AM
safe's Avatar
Cam oil line or tensioner oil line probably.
Magnus
Old 02-19-2007, 11:19 AM
kide's Avatar
Thanks Safe! I looked along the lines but couldn't really see any seapage... I will search more.
Old 02-20-2007, 12:33 AM
Could also be the dizzy shaft seal...check both.
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-20-2007, 08:02 AM
kide's Avatar
It was cam shaft oil feed line, behind heater duct. I am going to order parts and try fixing it myself.
Thanks!
Old 02-21-2007, 02:53 AM
safe's Avatar
Nice! An easy job, you may need to to remove the dizzy, not sure how looks on a 3.2.
Magnus
Old 02-21-2007, 03:07 AM
R & R Carrera 3.2 liter Cam Oil Line - left side:
1987 Carrera 3.2
Old 03-10-2007, 04:51 PM
